Does Sky HD output Dolby Digital 5.1 via HDMI?
Discussion in 'Sky Digital TV Forum' started by PaddChas, Aug 28, 2006.
  1. PaddChas
    PaddChas
    Jul 22, 2002
    20
    Folks,
    As the title suggests - please can you tell me whether Sky HD outputs Dolby Digital 5.1 from the HDMI socket, or is it just from the optical out?
    Sorry i know the FAQ says it does but i've read other threads saying it only outputs stereo..
    If it's just the optical out, can anyone recommend a good solution for splitting the signal in order to get 5.1 to two rooms?
    James
  2. DaveWolf
    DaveWolf
    Oct 17, 2005
    65
    +3
    No.
    2 channel only via HDMI.
    5.1 only on the optical.
  3. Geo772
    Geo772
    Dec 15, 2005
    39
    +5
    I'm glad I read this as I'm getting SKy HD installed on the 12th and had wondered this myself. The guy at sky when I ordered it didn't know.
    Better get a nice optical cable on order as well.
  4. PaddChas
    PaddChas
    Jul 22, 2002
    20
    Thanks for clarifying this - worth noting that the forum FAQ says otherwise.
    Given that I can only get 5.1 from the optical out, please can anyone recommend the best way to extend into a second room? Optical splitter? Amplifier? Convert to coax first or not? Extend using Cat5 or other?
    James
  5. ailean
    ailean
    Jan 17, 2006
    586
    43
    +153
    Gefen do some boxes that can combine DVI and Opti into a HDMI output, in theory you could use one of these and then use HDMI to distribute HD+5.1 digital around the house... in theory. ;)
  6. aerofly2
    aerofly2
    Oct 30, 2005
    130
    +13
  7. CrispyToast
    CrispyToast
    Jan 21, 2006
    412
    Llantrisant
    +13
    Is this the limit of the sky box or the HDMI cable?
  8. mitchec1
    mitchec1
    Jul 20, 2006
    3,794
    Birchington
    +2,027
    its the sky hd box:rotfl: :rotfl:
  9. DaveWolf
    DaveWolf
    Oct 17, 2005
    65
    +3
    After spending £150 on an HDMI cable it better be the effing Sky box. :thumbsdow
    (long cable) :)
  10. CrispyToast
    CrispyToast
    Jan 21, 2006
    412
    Llantrisant
    +13
    I am not surprised :devil:
  11. mitchec1
    mitchec1
    Jul 20, 2006
    3,794
    Birchington
    +2,027
  12. DaveWolf
    DaveWolf
    Oct 17, 2005
    65
    +3
    Yep signed a while back.
    (the excessive cable goes from my amp to the PJ and I am VERY happy with it - quick plug for hificables where it came from)
    Was slightly annoyed that I had to shell out for another optical cable when I realised that the SkyHD box was not pumping out DD on it's HDMI. I then had to spend a rather painful couple of hours trying to figure out how to get the amp to listen to the optical cable rather than the HDMI one. Turned out it was very simple (if only I'd bothered to look in the manual) - special button on the remote to do it, I was fighting my way through its menu systems. D'oh.
    (Yammy RXV1600 BTW)
  13. mcthart
    mcthart
    Jan 24, 2005
    10
    really sorry to resurrect an old thread but this was the most relevant one i found whilst searching for help...
    i've just bought myself a Denon 1910 and want to run DD out of my Sky+ HD box...i've tried putting an optical cable in and remapping the inputs on the AVR but i think the HDMI is hogging the limelight in terms of where the AVR listens for audio...can anyone help me find out where i can switch off the HDMI audio and use the optical cable please?
    many many thanks :)
  14. hot-fuzz
    hot-fuzz
    Dec 13, 2005
    6,086
    Hampshire/Surrey, UK
    +593
    Its your amp thats the issue, the i would look in the Amps section of the forum and possibly post there.
    More likely to get people who own your amp replying.
    :thumbsup:
  15. grahamlthompson
    grahamlthompson
    Aug 3, 2006
    24,450
    Redditch
    +4,159
    It's normally in the HDMI setup options on Denon amps. You have to change the settings to pass audio straight through to the display for the hdmi input the sky box is connected to.
