Does SKY+ digibox output RGB Sync on G (RGsB)?
Discussion in 'Cables & Switches' started by Eye in the sky, Nov 19, 2004.
  1. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    I tot I will post this thread here so maybe I can cast my net further to get the answer.
    I can't find the answers anywhere. Maybe I did not look hard enough.
    Can someone tell me if the SKY+ digibox output RGB with SYNC on G??? When I switch the video output to RGB does it output RGsB???
    Thanks.
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    The Sky digiboxes output RGB with sync on composite. Hope this helps.
    Steve
  3. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    is there any way where the SKY+ digibox can be programmed or flashed to output RGB SYNC on G?
  4. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    No idea, I'm afraid. What is the display you want to connect to?
    Steve
  5. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    its a Panny PHD7 plasma. The Panny component Video terminal board supports RGsB.
  6. Rob100
    Rob100
    Nov 3, 2002
    3,482
    +227
    Sounds like to need a RGB2VGA converter...
  7. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,581
    The Borders
    +3,030
    Eye in the Sky - (must be a chopper pilot or CCTV operator :))
    As others have said the SCART output on your Digibox is RGB+Composite sync.
    If you have the TY-42TM6YB Board installed in your Display you can add in either the JS Technology RGB2VGA (5 core) or RGB2YUV (3 core) connector and cable set.
    The RGB2VGA (RGBHV) is slightly sharper than RGB2YUV - though you have less control of the colours on the VGA input and the YUV converter gives you the option of switching the signal via a suitable AV Receiver if you have multiple YUV signals.
    Another option is to go for an external Video Processor - much more expensive but gives you far better video processing than the on-board processor in the Display.
    A Lumagen VisionDVI at SRP £815.00 should be your starting point and this accepts an RGB+Composite sync signal so all that's required is a straightforward SCART to 4RCA cable.
    Best regards
    Joe
