Does SKY+ digibox output RGB Sync on G (RGsB)?
Discussion in 'Sky Digital TV Forum' started by Eye in the sky, Nov 19, 2004.
  1. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    I can't find the answers anywhere. Maybe I did not look hard enough.
    Can someone tell me if the SKY+ digibox output RGB with SYNC on G??? When I switch the video output to RGB does it output RGsB???
    Thanks.
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,469
    Southampton
    +188
    sync is on composite.
  3. Eye in the sky
    Eye in the sky
    Nov 19, 2004
    83
    So SKY+ does not output in RGsB then. In this case, what would be my best options if I still want to connect using the SKY+ RGB via scart to RGB-Sync-On-G? Is there a suitable converter that can do a good job?
    Thanks.
  4. pjclark1
    pjclark1
    Jul 19, 2004
    4,411
    Thailand
    +271
    sync on G is only in the USA
  5. mbower
    mbower
  6. MarkE19
    MarkE19
    Aug 10, 2002
    17,130
    Rainham Essex
    +2,392
    RGB with sync on composite is the standard used in the vast majority of scart sockets. So if you are connecting Sky+ to an RGB compatable recorder/screen etc via scart then it will be compatable and no conversion required. If connecting to a plasma screen etc with no scart sockets then the chances are you will need to convert the RGBs to RGBHV or perhaps YUV component. This can be done with the boxes from www.js-technology.com which I can highly recommend as giving great PQ.
    Mark.
