Does Sky+ and multiroom require twin LNB??
Discussion in 'Sky Digital TV Forum' started by artois, Apr 17, 2005.
  1. artois
    artois
    Jan 17, 2005
    813
    28
    Edinburgh
    +40
    Hi I am currently waiting to get a sky plus box with the multi room option with free installation from sky. I have been reading on the forums about twin LNB etc and was wondering if I shall need to get this aswell. Basically my setup will consist of the normal difgibox downstairs, sky + upstairs and the multi room sky package. I am not sure if I must change the lnb and if I do require a twin LNB what purpose does it serve? Appologies if its a silly question but Sky never mentioned anything about an lnb change. Thanks vey much
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    SKY will be supplying and installing a Quad LNB which will feed the SKY+ and multiroom digibox with one spare feed if you want to add another box at a later date.
    Nothing to worry about:)
  3. artois
    artois
    Jan 17, 2005
    813
    28
    Edinburgh
    +40
    Superb, Thanks for the info Starburst. Thats ideal :thumbsup:
