Does size matter!
Discussion in 'LCD & LED LCD TVs' started by andrewf, Sep 1, 2005.
  1. andrewf
    andrewf
    Apr 26, 2005
    1,027
    48
    +28
    Simple question(s) - have a 32" CRT and am going to buy an LCD - choices down to the last 3/4.
    Have been looking at 32" cause of the price. For those of you who have a 32" on the wall, does it seem smaller than a 32" CRT?
    Even though it will be pushing the budget limit, should I be 'investing' in a 37"?
  2. holtehero
    holtehero
    Sep 10, 2002
    2,790
    Cambridge
    +1,785
    I went out at the weekend and had a look at the LCD's in Curry's (actually hate the place but thats another story). I currently have an old 32" Phillips CRT which is pretty big and the screen is quite a away into the lounge.
    I was shocked at how phycisally small the 32" LCDs were to be honest. This is good from a space saving perspective, but for me the screen will be about 2 feet further back from my current viewing position, therefore for me 32" is not really big enough for LCD
    So, I have now decided that it needs to be either a 40" LCD or above or a DLP RP
  3. daveon
    daveon
    Mar 31, 2005
    1,635
    Washington
    +126
    You have kind of answered a question for me from an earlier post about 32" or 37" lcds. I had never even considered the fact that you are actually further away from an lcd than a crt, excellent point well made, oh well looks like I need to find the extra £700 for the 37" LCD then.
  4. andrewf
    andrewf
    Apr 26, 2005
    1,027
    48
    +28
    kind of what I've been thinking too, though worryingly it could take me another 4/5 months to save the extra to step up.
  5. televisionuser
    televisionuser
    Dec 28, 2004
    588
    +11
    Depends on what you're using it for. If you want to watch films and have that cinematic feel, go for a screen as large as possible (37" or bigger). Whereas if you're just going to be watching TV, you may find it too big and tiresome for something very ordinary like watching morning TV or the news. Also you probably don't want something too big if you intend to play games as prolonged viewing on a very large screen again could get tiresome.
  6. holtehero
    holtehero
    Sep 10, 2002
    2,790
    Cambridge
    +1,785
    Its not something you automatically think of, but it is definitely something that surprised me, as well as how small the whole unit was. I actually made sure a couple of them were 32" (Sony S32 and one other) as they looked tiny
    Also, i guess it depends if you plan on wall mounting or not or buying a stand to put the LCD on, either way if you are switching from a CRT then i think many people will be surprised at the physical size.
    I at least now know that i need at least 40", though i think anything from 40 to 46" would be right for my viewing distance, when taking screen position into account
    I also looked at a Samsung 50" DLP, but that was too big :cool:
  7. andrewf
    andrewf
    Apr 26, 2005
    1,027
    48
    +28
    thanks televisionuser
    planning to watch TV, DVD and use for games so your comments do add something to think about.
  8. andrewf
    andrewf
    Apr 26, 2005
    1,027
    48
    +28
    can anyone remember the recommended size screens v distance to the seating position? I've seen the list somewhere in the forum but cant recall where
  9. televisionuser
    televisionuser
    Dec 28, 2004
    588
    +11
  10. televisionuser
    televisionuser
    Dec 28, 2004
    588
    +11
    Also, another thing to bear in mind which you may already be aware of is the resolution. On the Samsung 32" (before I returned it) I found that the resolution of a high quality SDTV video of 640 x 480 was a bit too low for a screen of this size. Also, the 480p XBOX games didn't look so great, whereas on a 15" lcd they looked good. For a screen of 37" or larger I would be looking for something with a native res of 1080p although I think they're quite new and expensive.
  11. benwong
    benwong
    Dont forget though, the diagonal size of a 32" LCD screen is literally 32" from corner to corner. On a CRT, 32" often refers to the distance between the corners of the housing of the screen.
    So therefore a 32" LCD has a larger viewing area than a 32" CRT.
    Try measuring your CRT screen..
    Ben
  12. s3marc
    s3marc
    May 10, 2005
    134
    +5
    BenWong is right.
    a 32 inch CRT is usually around 30.5 inches actual screen size , a 32 inch LCD is 32 inches.
    so LCD is actually bigger than their CRT relatives.
  13. thelawnet
    thelawnet
    Aug 21, 2005
    102
    that's because they're flat! If you want it to be 2 feet closer, put it on a stand 2 feet closer to you :)
  14. holtehero
    holtehero
    Sep 10, 2002
    2,790
    Cambridge
    +1,785
    agreed, yes i could put it on a stand 2 feet closer too me or even sit 2 foot closer to the TV if mounted it on the wall, however that sort of defeats the object in my case. I also realise the size thing as it is the same as CRT and LCD monitors and the figure quoted is the actual size viewable with LCD
    I was merely stating my surprise at going to look at LCDs TVs for the first time seriously and not realising how small they look. I think many people who currently own a CRT don't consider this factor when thinking of purchasing (especially if they buy online without viewing)
  15. benwong
    benwong
    Also don't forget, it's very easy to loose the sense of perspective when viewing these screens in a huge store like currys etc..
    Many people are suprised at how big a screen actually is when it's delivered to their house because 'it didn't look that big at the store!' :smashin:
    Ben
  16. ianh64
    ianh64
    Aug 7, 2004
    2,233
    SW London/Surrey borders
    +63
    And then thankfully over the next few days the screen shrinks back again so is no longer the monsterous thing that totally dominates the room.
  17. gareth78
    gareth78
    Nov 25, 2004
    97
    Woking
    it always seems incredibly difficult to judge the actually size when you have been looking at some massive 60 inch plasma moments earlier, i have a 28" CRT and whenever i look at those in the shops they seem tiny but mine looks quite a nice size in my small living room (thats until i get my 37" lcd in the next couple of months :) )
  18. andrewf
    andrewf
    Apr 26, 2005
    1,027
    48
    +28
    cheers for all the links and help. plenty to muse on :)
  19. rhubarbe
    rhubarbe
    May 25, 2005
    4,668
    Cheshire
    +211
    Er, no actually, it isn't. :nono:
    If you read the specs, you'll see that some of them are 80cm, some (Tosh) are 81cm and the odd one (32LD7200) is 82cm. That's very nearly an inch difference, and 80cm is just a gnat's d*ck less than 31.5".
    So there.
  20. TankTopLover
    TankTopLover
    Aug 28, 2005
    4,119
    +187
    My toshiba 31" is 81cm.. it has 'Frame 3' technology :rolleyes:
    Sound slame but its exellent,the screen is huge and has exellent pq.Any larger than 32" screen for me is overkill IMO.
