Does size matter ? 434-XDE vs 505-XDE
Discussion in 'Plasma TVs Forum' started by philgreeen, Jan 10, 2005.
  1. philgreeen
    philgreeen
    Jan 2, 2005
    50
    Hi all,
    (I posted this on the LCD forum earlier so apologies for any duplication !!)
    I have read various reviews and I'm looking to purchase the Pioneer PDP-nnn-XDE plasma but can't decide whether the 43 inch or the 50....
    I have a lounge 22 feet long with the seating arranged such that the plasma will be approx 15 feet away, although other seating will be approx 6-8 feet away at a 90 degree angle.
    Obviously this is a little subjective but has anyway got any views on the merits of the 43 vs 50 inch screens ??
    Cheers !!
  2. loonatic
    loonatic
    Jan 4, 2003
    1,925
    41
    Springwell Village, Gateshead
    +16
    Well I view my 50" MXE1 from about 12ft and it suits me fine...it really is a personal choice as you say but get too close and you start to see the image structure.
    Also depends a little on what you will watch the most...if mostly TV type shows via Sky/Freeview then the 43" might be more suitable but if it will mainly be DVDs then the 50" might be better.
    I would have thought your room could take the 50" though...just make sure you get one of the best seats.
    Cheers, Lee
  3. ScubaPro
    ScubaPro
    I sit about 17ft from my plasma and am really glad I went for a 50" now, it looks perfect but I think a 42" would not give the big screen experience (projectors aside), so my advice would be get the 50 ", you know you want too !
  4. EdwinB
    EdwinB
    If you plan to use it mainly for watching films then I would go for the 50". On the other hand, if you rarely watch films and just like to watch tv shows then a 43" might be better.
    Edwin
