Does RGB pass-thru work OK
Discussion in 'Blu-ray & DVD Players & Recorders' started by Jon Weaver, Oct 3, 2001.
  1. Jon Weaver
    Jon Weaver
    Aug 16, 2000
    6,202
    Born in Bristol but now in Newport, (for my sins)
    +739
    I have a TV with 1 RGB scart and 2 devices (DVD and PS2).
    I have always had my DVD and Games console connected via a SCART switch, which works.. But its a pain.
    It also means that its a waste to use a quality scart cable as the switch is in-line.
    One of my pre-requisits for my new DVD player is 2xSCARTS
    It looks like I will go for a Pioneer 545, but I wondered if anyone is using the RGB pass-thru feature.
    Does the DVD player pass through the RGB signal when its in standby without any ill-effect?
    Is there anything else to consider?
    Any info appreciated
    Jon
  2. Paden
    Paden
    Jul 27, 2000
    578
    +23
    Hello Jon
    I've got my digibox running through my DVD player with no adverse effects that I can see, very handy!
    Cheers, Paul.
  3. Doubledoom
    Doubledoom
    the sony x25 and x35 ranges have 2 scarts and pass through works fine.
    I did have pass through between my digibox and Sony 725 until i moved over to component video for the dvd player.
