Does pw7 hdmi board work in pw6?
Discussion in 'Plasma TVs' started by bjcol, Dec 30, 2004.
  1. bjcol
    bjcol
    Jul 8, 2002
    24
    Bristol
    Could anyone tell me if the Panasonic HDMI input board for the pw7 will work on the pw6(which I have)? I have seen from postings that people are starting to receive their HDMI boards that were on order and wondered if anyone had tried this combination yet.
    Thanks in advance.
    Ben
  2. Lizzard
    Lizzard
    Maybe, if you are good at reverse engineering :D
  3. bjcol
    bjcol
    Jul 8, 2002
    24
    Bristol
    I notice that many of the other inputs boards for the pw7 are exactly the same models as the pw6 ones so I reckon theres a good chance, they must have identical size / connections. Anyone know?
  4. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Yes I know. Definitely not.
  5. bjcol
    bjcol
    Jul 8, 2002
    24
    Bristol
    Thanks for the info.
  6. Andrew_P_S
    Andrew_P_S
    ...doesn't even work in a pw7.... !
  7. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    ?? :confused: ??
  8. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Panasonic board work in one generation of plasma to another? You're having a giraffe mate.
    I can tell you now that Series 8 board won't work in Series 7 screens either.
    Build in redundancy is Panasonic strategy, they would rather you upgrade whole new screen than just card. :)
    StooMonster
  9. Andrew_P_S
    Andrew_P_S
    Sorry - flipant remark!
    ...borne out of the frustration that the HDMI board for the 7 series will not support the European 50Hz HD broadcasts..... possibly
  10. geeWcee
    geeWcee
    Oct 27, 2003
    1,402
    West Yorkshire
    +25
    I gathered... ;) You got a PW7 then?
  11. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Got a Panny 50" Series 5 where only digital signal is 1024x768@60Hz -- whereas analogue supports almost everything, and internal frame-buffer supports 48Hz, 50Hz, 60Hz and doesn't mess about.
    Watched with interest as Series 6 and Series 7 have poor digital signal support, and wondering if Series 8 will be better. If any of these offered native 1366x768 @ 50Hz and 48Hz (for NTSC movies with no nasty 3:2 pull-down judder) I would've upgraded my screen in a flash.
    Now my upgrade criteria includes higher resolution, I want 1920x1080 plasma with 50Hz and 60Hz support on digital inputs. :devil:
    StooMonster
