You might as well try your current cable first. Turn on 120fps and ray tracing and see if it works. You might be ok.I have QED performance, the flat profile ones built into the wall. They are about 6 yrs old now I’m taking it to get the most out of my ps5 and new oled that I need to replace them ??
Yes very true, would the information be on the PS5 or tv to know if it’s working ?You might as well try your current cable first. Turn on 120fps and ray tracing and see if it works. You might be ok.
