does ps3 upscale avi's
diggle
hi all:hiya:
ive searched but i cant find nothing:rolleyes:
im jjust wondering does the ps3 upscale avi movies that are being streamed to i by tversity through the component hd cable:rolleyes:
thanks all:hiya:
Uridium
hi all:hiya:
thanks all:hiya:
Yes. Upscaling of HDD or Network streamed media was added in a firmware update mid 2008.
(Ps3 Media Server will do a better job than TVersity btw ;))
muckybucket
I assume it will output at whatever resolution you set it to. Certainly if you ran it through an AV system upscaling would occur if set to do so.
As I run my PS3 through an AV system I cannot verify if the native video stream is upscaled...
diggle
cool:cool:
so let me get this right. if i played the same avi in a dvd and on the ps3 would it look better on ps3:rolleyes:
muckybucket
Uridium is right, depends on your TV. Your PS3 would (probably) try to upscale to 1080p or i, but if your TV is 'HD Ready' then it would take a 1080i source and downscale itself to closer to 720...
Either way depends on your TV! If it supports 1080p output from the PS3 SHOULD be better...
diggle
cool thanks guys:thumbsup:
i just got my hd lead in the mail today i got to say my avis actually look quite good:clap:
diggle
e2a @ Uridium do you know if ps3 media server allows for movie cover art :rolleyes: i dont think tversity does i named a folder 1234 put movie and picture inside called 1234 it diddent show up on ps3
any ideas:hiya:
