Does panny E50 or E60 play DVD+R/RW
Discussion in 'Blu-ray & DVD Players & Recorders' started by cj28, Sep 6, 2003.
  1. cj28
    cj28
    I'm thinking of changing my Philips DVDR890 for a Panasonic recorder (probably E60). However I have a collection of DVD+R and +RW disks. I know they obviously won't record on the Pannys but do they play??
    Cheers.
    CJ28
  2. Rasczak
    Rasczak
    Apr 3, 2002
    21,720
    Warwick
    +2,599
    Haven't used the E60 yet but other Panny recorders generally play DVD+R fine but, with a few exceptions, do not play DVD+RW. Having a look at the review of the E60 in HCC shows that "formats supported" include DVD+R but not DVD+RW - I know these aren't always that accurate but, in my experience, they tend to over-estimate what it can play, not underestimate it. Which would suggest it will not play DVD+RW disks.
  3. Ged
    Ged
    Apr 29, 2002
    946
    +24
    cj28,
    I have shelved the 890 for an E50, I still use a Sony 990v front end and have no problems, what I have done though is buy an S75 to dub RAM to dvd-r and they play on that also.
    Ged
