Jon Weaver
I have just discovered that using a JS RGB-VGA converter, I can use a 15pin to 5xBNC cable and connect to the RGBHV (same input as component) input.
Does this input (When in RGB mode) allow 'just'.. I know it does when in component, but what about RGB.
If si, this is brilliant news, as I can buy a VGA converter and use it on the component connectors (RGB) for now, then should I ever get a new DVD player, change the cable and move it to the VGA input.
However, this assumes that the Plasma will allow 'just' mode on the RGB/Component input, even when in RGB mode... Does anyone know whether it does?
