Does it pay to match to match up?
Discussion in 'Home Cinema Buying & Building' started by jon43, Feb 18, 2013.
  1. jon43
    jon43
    Jan 8, 2012
    16
    Swindon, Wiltshire
    Recently purchased a Samsung TV (UE46ES6300UXXU) and wanted to replace my LG 3D surround sound system (BH6620S) with a Samsung (HT-E4500/XU) so it would better match with the TV.
    Does it actually pay to match up?
    I can see a good and bad point which would be-
    One less remote to use
    On the Apps side of things you would end up with the same apps as on TV & Surround system with thesame make/brand
    Recently seen a review by Which? That gives my existing LG surround system a better rating than the Samsung surround system
    So need to decide what’s best
    Any suggestions guys?:lease:
  2. Gaspode_TWD
    Gaspode_TWD
    Jun 3, 2008
    721
    Thame
    +69
    Largely a matter of personal choice. Whats important is that the kit does what you want in the way you want.
    Many remotes can learn the commands for other makers equipment. Or you can buy a universal remote.
  3. Linx08
    Linx08
    Sep 29, 2008
    1,622
    Whittlesey, Cambs
    +191
    I would say its important to remember the 'sound' in the surround sound unit, have a listen to the samsung system if you like the sound then it would be a good buy, if its sounds kack it obviously wouldn't.
    Linx
