does iScan have diff NTSC / PAL models?
Discussion in 'Plasma TVs Forum' started by sub, Sep 24, 2003.
  1. sub
    sub
    To take advantage of our current exchange rate, I'm thinking about getting iScan Pro (possibly Ultra) shipped from the US to here in New Zealand.
    We're PAL, the US is NTSC. Does iScan have different models for different parts of the world, or is there only one multistandards model?
  2. sub
    sub
    ...I'm intending to use this for my Fujitsu P42VHA20. Out of the box it does a great job with DVDs, but I'm not so pleased with the picture from our sh*t analog cable network.
    I'm not expecting miracles, but I notice a bit of banding on moving objects through the composite signal from my cable box. I dont see this through the component input form my DVD, and I'm hoping the iScan will help fix this.
  3. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,911
    The Borders
    +3,126
    sub
    The Ultra and Pro dont do any form of scan conversion - input Interlaced PAL and they output 576P; input Interlaced NTSC and it outputs 480P.
    Go for the Ultra - its far more flexible and features like the Chroma filter easily justify the additional cost.
    Best regards
    Joe
    PS Visit www.dvdo.com - they are very helpful!
  4. Dale Adams
    Dale Adams
    Jul 9, 2003
    175
    +15
    sub,
    There's only one version (each) of the Pro and Ultra. Both of them are multi-standard, so they work with PAL and NTSC.
    - Dale Adams
  5. sub
    sub
    Thanks for the info guys.
    I had a chance to try one out locally today. It didn't really seem to do a job much better the built in fujitsu electronics. I could notice slight difference, but it was hard to tell if these were improvements. I think I've decided its not worth the dollars for my particular setup.
