does -HD player(1080p)+hdmi+NAS - exist?
Discussion in 'Blu-ray & DVD Players & Recorders' started by GarethR, Sep 20, 2007.
  1. GarethR
    GarethR
    I'm planning a dedicated home cinema, but as I can't do anything until I buy a better house (beamed cottages with low ceilings/beams in the way don't lend themselves to projector setups :) ) I'm planning a little upgrade for my existing kit that will also be of use when I set up my pj.
    In short, I want to be able to store lots of movies on NAS Hard Disks and be able to access them from the HD/BlueRay player (without the need for a full media PC setup).
    Is there anything out there that currently does this? (I don't trust USB streaming btw - I've heard it can be really crap).
  2. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    There is dedicated hardware for this, the drive is contained in the server, mediamax is what you are asking for. No player needed, but deep pockets are a must.
  3. tfboy
    tfboy
    Nov 17, 2005
    1,401
    Reading
    +455
    The alternative is an xbox360 with hd-dvd addon drive (although no hdmi unless you get the elite version). Or get a PS3 which can also stream and has hdmi output (but blu-ray and not hd-dvd).
    Can't think of anything else...
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    But neither of those can stream an HD movie, cos you can't rip them, and can't download them, well, you can't admit to it!
  5. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Looking at mediamax, is it not a PC based solution (albeit a fairly slick looking one)? They appear to have a disclaimer with regards to loading up your media onto the RAID arrays, so I assume it's not "official" like Kaleidescape i.e you need to rip your own media.
  6. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    No, you just pop the disc in the drive AFAIK, I've had my hands on one, but not done the process.
  7. cj
    cj
    Apr 6, 2001
    1,471
    Reading
    +74
    Ah yes they seem to rip your media for you as well. If it rips HD-DVDs then surely it must be running Windows?
  8. GarethR
    GarethR
    I've been doing some digging about and I've found out that there are dnla certified raid arrays out there (the 4Tb Terastation caught my eye ;) ) which means as long as I have a PC to rip my DVD/HD-DVD/Blu-Ray discs (which isn't too difficult) - what I essentially need then is a DVD player that can output 1080p (or at least 720p/1080i for now) over hdmi that is dnla certified.
    I know that the bdp-lx70 can do this, but at £820 notes it's a bit more than I was hoping for (especially when I'm looking at £1200 for the RAID array).
    Does anyone know of a cheaper player that could do this? :lease:
    Thanks for all the replies so far - I started out last week wondering about a pj, and now I'm half-way to knowing about dvd-menu stripping and media centers - what the hell have I got myself into!! :rolleyes:
    Edit: ok, found something - Buffalo PC-P4LWAG £110 from Amazon..that'll do nicely :)
