Does CD93 support PowerToggle?
Discussion in 'Arcam Owners' Forum' started by raymci, Aug 9, 2005.
Tags:
  1. raymci
    raymci
    Aug 24, 2004
    29
    3
    +3
    I've seen a few forum threads relating to the use of a Power Toggle RC5 discrete code on some of the Arcam CD players. I don't seem to be having any success getting it to work for the CD93 player specifically and wondered if this model actually supports the command?
    The supplied manual has none of the supported RC5 codes listed.
    Any advice welcomed.
  2. ANDY_DUTTON
    ANDY_DUTTON
    Aug 27, 2002
    498
    28
    Cambridge
    +87
    The CD93 does not have any standby function hardware. Hence it does not have a power toggle command in its RC5 remote operations.
    If you want a standby option on your player the ARCAM players that support this are;
    CD73
    CD192
    CD36
    Regards,
    Andrew
  3. raymci
    raymci
    Aug 24, 2004
    29
    3
    +3
    That explains it... thanks Andrew :)
