Does ATI DVD player do surround?
Discussion in 'Desktop & Laptop Computers Forum' started by Markus, May 26, 2002.
  1. Markus
    Markus
    I just got a videologic sonic fury soundcard with the aim if surround sound. I have one stereo plugged into the front output and one stereo plugged into the rear output. I am using the ATI DVD player with DVD genie and set the audio to 4 channel downmix but just get the same audio signal coming out of both sets of speakers. I have also tried pro-logic and 3 channel downmix and they don't change anything, the sound signal is the same to both sets of speakers. Is this a problem with the ATI DVD player? Any suggestions?
  2. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    The ATI DVD player ( at least the last version I used last year) only supports DD5.1 by passing the whole lot to an external decoder.
    To decode internally like you want to do you need to buy PowerDVD, or perhaps WinDVD. You need the up-market version of PowerDVD, so it aint cheap, but you get full DTS and DD 5.1, prologic etc. decoding.
    It will run in 2 4 or 6 speaker output mode, and will mix the LFE channel into the front speakers if you don't have a .1 speaker.
    In 4 channel mode it mixes the centre channel into the fronts as well.
    I used in 6 channel mode with a sonic fury until a few weeks ago when I replaced it the sonic fury with a delta 410.
  3. RichardH
    RichardH
    Apr 8, 2002
    753
    Hertfordshire, UK
    So did the Delta improve the sound significantly?
  4. Pootle
    Pootle
    Apr 14, 2002
    149
    Staffordshire
    Definitely an improvement, but not as obvious as changing my SB Live! for the santa cruz, the extra speaker management facilities are excellent.
