Does anyone make a high quality scart splitter
Discussion in 'Cables & Switches' started by CARLOS, Nov 2, 2004.
  1. CARLOS
    CARLOS
    Feb 11, 2001
    6,441
    WEST MIDLANDS
    +1,411
    I`m looking to split an RGB scart signal into two without any quality loss, Anyone know of anything ?
    Cheers, Carl
  2. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,581
    The Borders
    +3,030
    Hello Carlos
    Very few if any really high quality SCART splitters around.
    If you can live without WSS and bi-directional Audio/Video and simply require to duplicate the RGB Video signal then you can start to utilise alternative 'non SCART' products.
    We import and supply the Zektor range of Component video switchers to the UK and Europe. The HDS4 can be used as a 4:1 switcher or a 1:4 Distribution amp - you simple wire it in reverse.
    Using a decent set of SCART to 4RCA Phono cables you can assemble a 1:4 SCART 'RGB Only' distribution amp with ease - though this option only allows you to View the Source on One Display at a time. See http://www.zektor.com.
    If you want to view multiple RGB feeds from the same Source simultaneously we have alternative products that would fit the bill - though it starts getting quite costly.
    Any questions please shout.
    Joe
  3. GrahamC
    GrahamC
    Jul 22, 2001
    2,259
    Morecambe, U.K.
    +67
  4. CARLOS
    CARLOS
    Feb 11, 2001
    6,441
    WEST MIDLANDS
    +1,411
    Joe thanks for the reply, I thinks thats going to be a bit OTT for what i`m looking for unfortunately ;)
    Graham i already use JS products, Unfortuunately they don`t do a scart splitter so not a lot of use :smoke:
