does anyone know where to get ac adoptors/plugs for ...
Discussion in 'AV Receivers & Amplifiers' started by Gary Palmer, Dec 21, 2000.
  1. Gary Palmer
    Gary Palmer
    Jul 17, 2000
    333
    16
    Try Maplin
    https://catalogue.maplin.co.uk/mainframe.asp
    I think you're describing the IEC socket (cable & plug order code is BW99H £2.99)
  2. Jesus H
    Jesus H
    its not IEC, which i think is the one you use to power computers/printers etc, its a 2 pin affair.
    thanks for the website though, i'll keep looking.
    'This one's got a bad mmooooooooooooooooootivaaaaaaator (in a very camp voice)'
    member formerly known as hank hill
  3. Jesus H
    Jesus H
    it looks to be similar to a european plug, if not the same, but with a limited acceptance for plug shapes.
  4. Jesus H
    Jesus H
    ... powering other devices from the amp, i.e using the ac sockets on the back of the amp.
    my DVD came with one, but i cut it off as i di not have an amp then and i think it was thrown out. Plugs i have seen will not fit the small hexagonal shape of the socket surrounds and shaver ones dont work either
