Does anyone know the size of bannana plugs used on the back of Home Cinema amps?
Discussion in 'Cables & Switches' started by MuffKing, Nov 6, 2004.
  1. MuffKing
    MuffKing
    This is the amp, a Panasonic SA-XR25
    [​IMG]
    I've tried using 2mm and 4mm bannana plugs (below), but 2mm is to small & 4mm is to large.
    [​IMG]
    [​IMG]
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    In general they should be 4mm plugs. I've certainly not come across any major variations from that lately.
  3. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I'm amazed you missed this one John, the caps are still in the sockets :D
    Muffking you need to lever out the black plastic caps from the center of the four screwdown terminals, this will reveal some lovely 4mm sockets for you to use :smashin:
    Cheers, Mylo :smoke:
  4. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    Can't see that on my monitor, I've got it set very dark so it's easier to look at Office programs with :)
    As mylo said, if the caps are still in then you just need to lever them out and you should have some nice 4mm sockets. Strangely, those binding posts look the same as on my Denon 1802 so I should really have noticed :rolleyes: They're a real pain to get bare wire in so I'm not surprised you want to move up to bananas!
  5. MuffKing
    MuffKing
    I wish it was that easy, but i've already had the 2mm plugs in the sockets as there are no caps in there, but it's like ringing a bell if you know what I mean ;)
    Mylo: Do you have kids that watch to much Tweenies by any chance :)
  6. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I was Mylo first though:laugh: comes from Myles
    I hate that program but my nieces and nephews love it :mad: :laugh: .
    From the pic it definately looks like the caps are in, they are a few mm long so you need to lever them out using a small screwdriver or similar. Give one a try and you may be surprised. I was caught out by this on my first amp :blush:
  7. MuffKing
    MuffKing
    I am so not worthy :smashin:
    I stuck a screw in there to pull the hollow black plastic insulator out in the end.
    [​IMG]
  8. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    sweet :smashin: glad to of service :thumbsup:
  9. MuffKing
    MuffKing
    Cheers mate. I just need to get some decent speaker cable now, and then eventually some decent speakers as i'll be moving house between now and xmas.
    I don't suppose you know if there are such things as plasma wall brackets which allow me to mount my Panasonic 42PA20 in the corner of the living room do you, as the only other place to wall mount it would be on the chimney breast in the middle of the room, but I don't know if it's safe to mount a plasma TV above a fireplace???
  10. Mylo
    Mylo
    Mar 13, 2003
    5,565
    +372
    I'm afraid not dude, but if you post a thread in the Plasma forum or the DIY one someone will almost definately be able to help you.
  11. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Muff king ave a look here:http://www.futureautomation.co.uk/Site4/Products/Pages/PS.htm mounts flat and pulls out to corner....!!! few other types available and there is a silver type one MAW has details on... ALso you can mount above a fire but need to make sure it suitbale older gas fires are a pain as heat goes straight up... NEw ones are designed to push heat 1-2m from grate into the room.. Plasma above these is fine...
  12. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
    You can buy plasma mounts with articulating arms for corner fixing
    Adrenochrome.
  13. Adrenochrome
    Adrenochrome
    Dec 20, 2002
    9,043
    Babel Sensurround
    +207
  14. MuffKing
    MuffKing
    hornydragon: I like the idea of mounting it above the fireplace. I'd consider changing the fire with moving into a new home and I know of a sparky who has the tools to chase the cables into the wall and fit a protective cover before having it replastered.
    Cheers Adrenochrome, £270 for this looks good. I'll perhaps show you guys some pics when I've decided which way to go.
    [​IMG]
  15. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    MUFF see the get your plasmas out for lads thread and get some pics on there...
  16. MuffKing
    MuffKing
    Yeah i spent hours last night browsing through the 80 odd pages installs and saved them to my PC
  17. Rbox
    Rbox
    Jan 9, 2006
    12
    I have the same problem with a Pioneer VSX-916. The speaker screws have a HARD plastic hollow center piece in them. Should I pull them out or just use bare wire connections. Pioneer help line didn't know this either.
  18. Luckypunk
    Luckypunk
    Muffking
    I am in the same boat as you and will shortly be mounting my 37" LCD above my fire place. I'm just assuming I will have sufficient protection from the mantlepiece wich extends a full 300mm from the chimney breast wall.
    However, I have still gone and purchased a bracket that may suit your needs, mainly because I want to be able to swivel the TV to face either side of the room. (This bracket also tilts as well +/- 15 degrees).
    I've done extensive research on this and the lowest price I had found was £170 for one suitable to hold the weight of my LCD. But this one, from a very reputbale seller on ebay, comes in at £85!!!!! P&P is £15 with insurance.
    The bracket will hold plasma/LCD up to 60" and 75kg. I only bought mine yesterday and so am currently waiting for it to arrive but i'm very confident its a really good deal.
    Hope this is some help mate.
  19. Luckypunk
    Luckypunk
  20. andykn
    andykn
    Feb 13, 2006
    4,731
    103
    +231
    If you mount over a fireplace it'll be very high up for a TV screen.
    I'd give it a try at that height for a couple of days first.
  21. dazzarooney
    dazzarooney
    do you need to solder the banana plugs to your speaker cable or are they grub screwed?
