does anyone know the correct size of d-link trunking for HDMI lead
Discussion in 'Cables & Switches' started by Sunshinewelly, Nov 13, 2017.
  1. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,033
    +446
  2. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,236
    +1,249
    It depends on the thickness of your cable but the majority should fit. The issue is the bend radius is quite small so, do you have (m)any bends?
  3. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,033
    +446
    i will have 3 bends in total
  4. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,236
    +1,249
    You might have a problem depending on the bend radius then, it can cause issues and especially where you are near the limits if you other thread at 8.5m better go fibre ...
  5. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,363
    The Borders
    +3,433
    Might be an idea to try and source a trunking which has a snap on 'lid' design - that way you don't require to pass the HDMI hood through the end of the trunking.
    Joe
  6. ChuckMountain
    ChuckMountain
    Oct 5, 2003
    6,236
    +1,249
    It usually opens one side, the other being a hinge, better check though.
  7. stevelup
    stevelup
    Aug 13, 2002
    6,715
    Swindon
    +1,223
    That d-line trunking does indeed snap open but as has previously been mentioned, I'd be worried about the bend radii.
  8. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,033
    +446
    tempted to actually slice the outer case as that may assist in its bendiness
    I simply cant justify spending £175 on a cable when the fibre cable itself looks problematic around corners
  9. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    28,363
    The Borders
    +3,433
    Hybrid Fibre HDMI - is currently the most reliable (and flexible) solution for 4K UHD once you are going beyond 8m.
    Cable route - ideally you would avoid tight bends, possibly time to look at alternative path ways.
    Joe
  10. Sunshinewelly
    Sunshinewelly
    Dec 1, 2005
    5,033
    +446
    Finally got a 8m cable to work from amazon. Took 5 different leads to get there
  11. stevelup
    stevelup
    Aug 13, 2002
    6,715
    Swindon
    +1,223
    Don't bend it ;)
