Does anyone have the 4.3 software for a DP?
Discussion in 'TAG McLaren Audio Owners' Forum' started by UrbanT, Jul 15, 2004.
  1. UrbanT
    UrbanT
    Jan 6, 2002
    12,943
    Aldershot, Hants
    +3,031
    I just picked up my 5.1 DP Tag this evening, and upgraded it with the only firmware available on the site, 4.31.
    After getting no sound, I've found on the forum you need a DPLIIx licence, which I believe costs £150. Can't say I really want to spend that.
    Is the recommended firmware 4.30? Whatever is recommended, could someone email, or give me a link to said firmware :)
  2. UrbanT
    UrbanT
    Jan 6, 2002
    12,943
    Aldershot, Hants
    +3,031
    PS my email is
  3. Miron
    Miron
    Sep 26, 2002
    1,428
    Vienna, Austria
    +53
    you'll need 4.1 for that, all after that is plIIx must be
    p.s. i sent you the software (but you'll have to trust me - i put no self exploding bugs inside) so remove that email addres of yours away before spam spiders web it.
  4. muellec3
    muellec3
    Jun 10, 2004
    42
    Switzerland
    +3
    Sorry Urban
    I only have 4.2, 4.3 and 4.31 on my system....
  5. UrbanT
    UrbanT
    Jan 6, 2002
    12,943
    Aldershot, Hants
    +3,031
    I thought I had read in another thread that only 4.31 had to have PLIIx?
  6. muellec3
    muellec3
    Jun 10, 2004
    42
    Switzerland
    +3
    Miron was faster - Greetings to Austria from Switzerland !
  7. Miron
    Miron
    Sep 26, 2002
    1,428
    Vienna, Austria
    +53
    ebenfalls
    hoffe du hast vieeeel spass mit allen tag kabeln aus ebay :)
  8. UrbanT
    UrbanT
    Jan 6, 2002
    12,943
    Aldershot, Hants
    +3,031
    I've just updated to 4.1 thank you Miron.
    It just remains for me to ask whether its worth the £150 to upgrade to PLIIx on a 5.1 system, so I can use software version 4.31?
    My system is run with an HCPC, and used 70% films, 20% PC games and 5% TV
  9. muellec3
    muellec3
    Jun 10, 2004
    42
    Switzerland
    +3
    Hi Urban
    IMHO it is worth the cost. I use it a lot for normal TV published in pro logic or normal stereo - and it really is a huge improvement over PLII.
    I never regret having made the upgrade.
    Buth that's just my 2c.
    Chris
  10. DanielB
    DanielB
    May 27, 2004
    158
    Switzerland
    +12
    Hi Urban
    It's definitely worth the cost, there are also some bug fixes and improvements in it. (in version 4.31)
    Regards Daniel
  11. roversd1
    roversd1
    The PLIIx option for the 5.1 unit basically improves the original PLII
