Does anyone have a Panasonic NV-MX350?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by Merritt, Aug 9, 2004.
  1. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Im trying to record from a VHS player to the camcorder (to put some old vhs footage on DVD). I have tried connecting the player and camcorder with a scart to svideo cable and a scart to the standard av input (as per the manual) but im getting nothing....
    Any ideas? :lease:
    Steve
  2. Brian110507
    Brian110507
    If you are using the scart adapter supplied with your camera that is your problem, these are all supplied wired 'IN' to the VCR, you need to pop down to your nearest Maplins and either buy a dedicated (and marked so ) 'OUT' adapter or the usual option is to buy a switched IN/OUT adapter so you don't need to keep changing plugs and leads.
    The scart to s-video option will not work unless you VCR is an S-VHS one
  3. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    Beejaycee - thank you for that! I had assumed that was the case with the svideo cable but thought I would give it a try anyway... the scart adapter block on the other hand :rolleyes: That hadn't crossed my mind!
    Cheers :thumbsup:
    Steve
  4. Merritt
    Merritt
    Feb 5, 2003
    263
    Hampshire
    FYI - I have just been out and bought a switched connector and it works a treat... Thanks again for your help.
    :smashin:
    Steve
