Does anybody know what size Hoya Filter I would need for a Sanyo Z1...?
Discussion in 'Projectors, Screens & Video Processors' started by Family Guy, Dec 6, 2004.
  1. Family Guy
    Family Guy
    49 or 52mm :confused:
    Much appreciated.
    Brian
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    The OD of the lens is 52mm.
    The front element itself is about 37mm dia.
    Best go for the larger diameter so you don't get any cut-off on the edges of the picture.
    The front of the lens doesn't appear to be threaded so I don't know what to advise you re. keeping the filter in place.
    Jeff :rtfm:
