Question Does a suitable screen exist?
kryton85
Ok, so I need another screen but just for a cheap POS projector I have running in the summer house. Bought one on Black Friday as don’t want to use my ls10500 or even the tw6600 in conditions where it might get damp. It’s mounted on back wall pointing at doors and I want to be able to open the doors so I can watch from the garden. I’ve put a £10 Amazon special up for now so know it works but need a solution that I don’t have to untack every time I want to go in or out.
Requirements:
16:9 & 72”
Backlit
White
Bar or weight at bottom
Retractable (motorised or manual)
What I ideally want is to be able to buy a roller blind that I can install so it doesn’t look out of place but use projection material instead of curtain material. I swear I’ve looked but can’t see a suitable solution much to my amazement. Flexible on ratio & size if supplied essentially as a roller blind
any input would be much appreciated.
