Does a Nokia 6500 work with TomTom Go
Discussion in 'Mobile Phones Forum' started by dudeness, Jan 18, 2008.
Tags:
  1. dudeness
    dudeness
    May 10, 2005
    2,082
    Poole, Dorset
    +309
    Just enquiring for a friend. He wants to buy one of the TomTom Go's and has to be sure that his Nokia 6500 is going to work on Handsfree with it, has anyone else got a 6500 on their TomTom, or can tell me if it'll work.
    Thanx:thumbsup::thumbsup::clap:
  2. RSRAVI
    RSRAVI
    Dec 15, 2003
    3,730
    71
    LONDON
    +85
    HI mate works with sim free nokia 6500 slide.........and tomtom 910.....hope that helps..........
  3. dudeness
    dudeness
    May 10, 2005
    2,082
    Poole, Dorset
    +309
    That's excellent, many thanx. :thumbsup:
  4. Member 55145
    Member 55145
    Jan 18, 2005
    12,082
    +3,481
    does the read and send txt msg function work too?
  5. RSRAVI
    RSRAVI
    Dec 15, 2003
    3,730
    71
    LONDON
    +85
    SORRY dont know ......only had phone for a while....
    handsfree worked plus tom tom traffic updates............
    throu the bluetooth too........
    not sure about textx never had the need to use that feature.......
    you find most sony phones work well with text on tom tom
    look here
    http://www.tomtom.com/phones/compatibility/
  6. supahoops
    supahoops
    Nov 22, 2006
    585
    28
    +34
    Hi All
    As per the title, i understand this fone works with the slider but i have a 6500 classic does TomTom work with the classic because there's no mention of it on the TOMTom website :confused:
    thx! :thumbsup:
  7. salsheikh
    salsheikh
    Apr 16, 2008
    98
    9
    hi, just tried the link and it does not show the 6500 on the nokia list. i bought the phone just so i can use the tomtom software on it but cannot find the correct software for the 6500 handset.
