Does a low level setting matter?
Discussion in 'Subwoofers' started by mikey999, Mar 11, 2005.
  1. mikey999
    mikey999
    I can guess that sub power rating is highly subjective (to the person and the sub).
    However, I have a 150w sub in a room that is about 30 metres squared (35 yards squared) and I only seem to need to turn the sub to about 2 out of 10.
    Does that suggest that my sub is over-powered? Alternatively, is it better to run a sub *well within* its capacity?
  2. Ian J
    Ian J
    Aug 6, 2001
    25,628
    +4,905
    The power rating of the amplifier in the sub has more to do with the size of the driver and enclosure than outright volume. My very first sub was a REL Q Bass that was a largish enclosure but only needed a 40 watt amp to drive it to fairly serious sound levels however many of today's subwoofers are in smaller enclosures and need more power to compensate.
    I think that the ideal gain setting for most subs seems to be between one quarter and one half
  3. mikey999
    mikey999
    thanks Ian. my sub is about 37cmx37cmx37cm, for the record.
