does a good power cable matter?
Discussion in 'Arcam Owners' Forum' started by RumNYC, Jun 22, 2005.
  1. RumNYC
    RumNYC
    May 31, 2005
    247
    Tokyo
    +9
    I have an arcam avr300 hooked up to a richard gray power company 400pro all using standard power cables. does upgrading to a USD$100 like ps audio plasma really make a difference? do i need to get 2 (one for the conditioner and one for the arcam)? anyone notice a real improvement?
  2. ruben20
    ruben20
    Jan 28, 2004
    76
    Netherlands
    +3
    I think you'd notice a better power cable in either position. Both positions is preferred. I certainly made a difference in my situation. I use a DIY solution, lapp cable(3 x 2,5mm2) shielded which is terminated with wattage and furutech plugs.
  3. radio
    radio
    Jun 1, 2005
    246
    Toronto, Canada
    +5
    Really the power cable will effect the sound? I am using hte standard 3 prong cable arcam came wiht it looks like a fairly beefy cable but its connected to a good conditioner... i didnt consider buying a new power cord?
    What are the differences or what should i be looking for in terms of improvement?
  4. bigfanga
    bigfanga
    I'm curious as to how, exactly, a power cord covering the last 6 to 8 ft will improve the sound of a system when there has been no improvement in the wiring of the house itself or in the line from the power substation to the house?
    Long story short, a power cord will make no difference in the sound. There's a reason that all of these companies producing high-priced cords and cables don't produce any scientific graphs or charts to show how their products improve sound: they can't.
    Just goes to prove Mr. Barnum's maxim...
  5. Sweden
    Sweden
    try ps audio, nordost etc they are fantastic great difference the best tweak you can do really.
  6. Greggles
    Greggles
    Mar 15, 2005
    1,069
    St. Saviour, Jersey
    +74
    Mains supply voltage can effect the sound (and picture) quality of hifi/ home cinema equipment as a result of:
    1) low, high and varying voltage;
    2) RFI (Radio Frequency Interference);
    3) EMF (Electromagnetic Fields);
    4) high voltage spikes;
    5) high impedance, poor extension leads, bad connections;
    6) poor and noisy earthing; neutral faults; fuses;
    7) interference from appliances and light switches;
    8) mains noise and harmonics;
    9) mysterious clicks, pops, buzzes and hums!
    ( from Russ Andrews publication "The Power and the Glory")
    Bigfanga logically asks how a power lead can make any difference! I was very sceptical myself but am now a total convert. Yes by all means start by rewiring the house, but this is not always practicable. Simply put, a good quality mains lead can produce great improvements to a system. I've heard various pseudo-scientific explanations as to why this may be the case, but for me it was just a case of listening to the difference. I would ask anyone who doubts the logic of this to give it a try, starting with your primary source and working your way down the system.
    Incidentally, I have found that upgrading the mains cable on my Gaggia has made no discernable difference to the quality of my espresso (sic)
  7. Mark F
    Mark F
    May 2, 2005
    387
    28
    +37
    Fully agree. I upgraded to Russ Andrews Powerkords about a year ago (around £75 each although they always have special offers on). The difference is unbelievable - the most cost effective upgrade I've ever done. Check out their website for the science behind it including graphs! They even offer a money back guarantee if you're not satisfied.
  8. tvh3ad
    tvh3ad
    Jan 19, 2005
    339
    +15
    I've not tried changing the power cord, but I did have an EquiTech "Son of Q" balanced-AC box on loan from my local dealer last weekend as part of a noise-diagnosis/elimination process. My audible system noise turned out to have nothing to do with the AC supply, but I can now speak to the effect of AC quality on the sound: in my particular case, the sound is dramatically different with a cleaned-up power source.
    Having had that experience, I wouldn't be surprised to find that swapping the last 6ft of AC cable might have some effect as well, but I would hazard a guess that its magnitude probably depends on:
    - the state of the juice as it leaves your wall outlet;
    - your local environment EF/RF
    - the rest of your equipment (i.e, source, speakers, other cables)
    - your ears
  9. NAA
    NAA
    Jul 22, 2004
    19
    4
    Moscow, Russia
    I`ve try power-cords-upgrade in two steps. At first i`ve purchase in building materials shop good 3x2,5 shielded copper powercable and good brass plugs from "Kopp". 2 meters cord was cost 10 USD for all. I`ve just wont, will be difference or not. And i heard difference, but it was very little. Now i have "Supra" (Sweden) cords. It cost about 18 USD for 1 meter in Russia. Difference is so big, for this money, unbelievable.
