Does a dvd recorder....
Discussion in 'Blu-ray & DVD Players & Recorders' started by smallman28, Jan 17, 2004.
  1. smallman28
    smallman28
    record in a similar way to how a mainstream DVD is laid out.
    Basically if you were to put a DVD that you recorded yourself into a DVD drive on a PC would it look the same in terms of layout as one purchased in the shops?
  2. applevenus
    applevenus
    Yes. There's a specification for DVD-Video and in order to have the label 'dvd-video' it must conform to that spec.
    You'll see the usual .ifo .bup and .vob files
