does "21 pin connected" scart means rgb ?
P
piolo
I want to buy a scart cable to connect my TV and DVD (both rgb capable). I would like to know if I have to search for a RGB label on the box of the cable or the label "21 pin connected" is enough to have a RGB-scart capable cable ?
Thanks in advance
Joe Fernand
AVForums Sponsor
Piolo
A 'Fully wired' SCART cable will pass RGB - though an 'RGB only' cable will generally have thicker conductors and do a better job than RGB via a fully wired cable.
Do keep in mind an 'RGB only' cable has no Audio conductors - and its directional so when you install it follow the signal flow arrows.
Best regards
Joe
P
piolo
Thank you, now I know more about rgb. I think I'll go for an audio-video-rgb fully wired cable.
paolo
Podcast: LG C1 OLED + JBL Synthesis SDR-35 First Thoughts, plus TV Show & Disc Reviews & more
