Dodgy reception on Virgin Cable
Discussion in 'Cable TV & Virgin Media TV' started by m.stephens, Sep 4, 2007.
  1. m.stephens
    m.stephens
    Oct 9, 2006
    609
    28
    +44
    Wondering whether its my box or a widespread problem ?
    Symptoms:
    1. No picture and sound in 1 sec "pulses" - needs box unplugged and restart
    2. Displaying anything interactive (prog info etc) momentarily hangs video
    3. Specific channels have jerky video - UK Gold being an example
    Can't be bothered to ring them up as I don't have Virgin phone these days, so not only would it take all day, it would cost me real money !
  2. nialli
    nialli
    Apr 16, 2004
    469
    28
    +25
    Where are you? What box do you have? Sounds to me like you have an issue with your box, but it's often worth checking out the Virgin Media Status page to see if it's a local or national issue (not that it's always accurate) http://www.virginmedia.com/help/check/?category=portal&app=status
  3. m.stephens
    m.stephens
    Oct 9, 2006
    609
    28
    +44
    There are ongoing TV outages all over VM it would seem but nothing specifically for my postcode.
    The loss of picture business happened on 2 separate days but seems to be OK now.
    The jerkiness is quite bizarre. I've done some testing and it only happens on UKTV non-timeshifted channels.
    So UK Documentary freezes momentarily when you press the remote but Uk Doc + 1 doesnt. Same for UK Food, UK Style, UK History, UK Drama (no timeshifted version), Uk Gold, UK G2 but all the equivalent +1s work fine and so does UK Bright Ideas.
  4. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    your signal is low..thats all..
    the fix needs to be done at the green cabs..they need to move you up in the green cabs to a higher tap..which gives a much higher db
    easiest way is to phone them..
    turn the power off..
    ..say the box is on but no picture..they will say ok ill send someone out
    when the person comes..tell them picture freezes and you've been told by cs that you have a low signal
    job done
  5. essjay
    essjay
    Jun 7, 2006
    925
    43
    +110
    Signal could also be too high, either way you will need a service tech out.
  6. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    go into the engineers menu
    depending on ur stb model..power down..holding up and down arrow and power on..
    go to the singal status page
    if its red or orange your signal is lowl..
    if its above 32db it may be to high on some channels
    u need a anttuantor..get one of fle bay..99p
  7. m.stephens
    m.stephens
    Oct 9, 2006
    609
    28
    +44
    Strange that it has suddenly happened. And even stranger that it only affects those specific UKTV channels.
  8. Ernie_C
    Ernie_C
    Apr 2, 2006
    986
    46
    +111
    That says it all! I doubt your problem will go away on it's own.
    Your paying for a service including maintenance. Phone them now.
  9. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    uktv channels need a higher signal thats all..
    and it may have happend because someone down your road may have taken a sub from them..
    not enough room in the green cabs..person lives further down the road from you
    so they move your cable wire at the top of the taps..which give a weaker signal whereas the person further down the road needs to stronger signal so he put the new customer on the stronger tap
    also your cable wire may have got a cut somehow..and obviously its causing your channels to freeze
    customer services wont tell you this because they dont know how the system works.
  10. Kebabhead
    Kebabhead
    Mar 7, 2006
    7,157
    +508
    Over the last few weeks I have been experiencing intermittent picture freezing on various channels on the STB. Seems to last a few seconds but doesn't require STB to be rebooted
  11. m.stephens
    m.stephens
    Oct 9, 2006
    609
    28
    +44
    Strange to say, it just has. I tried the business of rebooting holding down the Up and Down ( + and -) on my Pace 1010 and didn't get the engineer menu but the problem disappeared. I regularly have to reboot (i.e unplug from mains and reconnect) anyway in order to get any programme info and the problem persisted through several reboots previously so I can only assume that this was a fault which has now been fixed.
    I could go along with the business of UKTV channels needing a stronger signal if it wasn't for the fact that the UKTV +1 channels didn't -maybe because they have that extra hour to make their way along the cable ?
    I have found the "Technical Stuff" screen on the Settings menu and this shows a SNR of 35.0dB. I'll dig out the 6" long stack of attenuators which used to stick out of the back before they installed BB and see if dropping the SNR to 32dB improves reliability.
    I would really love to get an engineer out every time it goes wrong, but as I now pay for the hours it takes to get a real person on the phone and I can't really afford to spend another entire day waiting for the engineer to turn up, it would be the last resort.
    Forgot to ask - how do I get to the engineer menu on a PACE 1010T and does it do any more than being able to look at the "Technical Stuff" page ?
  12. Ernie_C
    Ernie_C
    Apr 2, 2006
    986
    46
    +111
    Why don't you try getting your TV support via the appropriate newsgroup which is 'virginmedia.support.tv' - no need to use the telephone if you use that route and they'll even arrange to get a tech to call if necessary.
  13. OneTrouble
    OneTrouble
    Aug 20, 2007
    640
    28
    +28
    35db is way to high and will cause freezing pictures..
    to reboot the box without pulling the power out do this..
    on the stb..hold ok..left arrow and then tv..
    hold one after the other..but all need to be pressed together to reboot the box..so doing one and then letting go..doesnt work..you need to hold the buttons
    to get into the engineers menu..take the power out..hold the up and down arrow together..put power back in..give it 20 seconds to boot...if you get a black picture..it will be because the box is set to rgb...change your tv to composite and youll see engineers menu come up..
    but if your tv is in composite mode then engineers menu will come on the screen instantly
    no point asking vm people..they dont know anything..they only bill customers for the wrong amount..forward you to the wrong department..or say the problem will be fixed by 8 (when there closed)
    hope ive helped in someway
  14. Kevstir
    Kevstir
    Aug 22, 2005
    726
    46
    Falkirk
    +185
  15. resh1988
    resh1988
    Sep 6, 2007
    5
    Hi, just had a v+ box installed today, unfortunatly i couldnt be in, as i was at work, i have a 32 inch r88 samsung, but the picture looks really poor, and pixelated? does anybody know why? or can help? it is connected via hdmi and is set at 720wide, but looks poor. but it looks amazing on the ps3:lease::thumbsdow
  16. Cocacola
    Cocacola
    Mar 15, 2007
    263
    Liverpool
    +5
    Is the TV Display format set to HiDef HDMI?
    On remote select:
    Home>settings(8)>change display & audio settings (4)>TV display format.
    If the settings are correct, phone VM and ask them to send out another HDMI cable in case you have a dodgy cable.
    Should arrive in the post next day.
  17. CITY_MANC
    CITY_MANC
    May 28, 2006
    313
    Stockport
    +11
    Should have got a decent telly mate :rotfl:
  18. m.stephens
    m.stephens
    Oct 9, 2006
    609
    28
    +44
    The reset without powering off is a neat trick. I don't suppose I can do it with the remote somehow ?
    Despite the fact that everything is "back to normal" I tried putting a 3dB attenuator on the back. The engineer menu shows SNR green with or without the attenuator and the 3dB caused a drop from 34.5 to 33.5.
    The attenuator caused the combined AGC to intermittently drop below 300 and go red on 64QAM and it was almost permanently on red on the 256QAM screen.
    RS post error was occasionally red on the 256QAM screen without the attenuator and this increased when the attenuator was added.
    I think I will leave the attenuator off, as everything works as well as it is ever going to . I nornally use Freeview anyway and only need Virgin for the occasional programme.
