Toonaroond
- Joined
- Apr 17, 2006
- Messages
- 1,249
- Reaction score
- 33
- Points
- 283
Hi, bit of technical know how required. Have just bought a second hand Cambridge Audio A5 amp off Ebay and have tried it out with my Arcam CD62 and Wharfedale DIamond 9.1s.
Problem is that when listening at low volumes no/very little sound comes out of the right speaker. When you turn the volume up a bit, sound comes out of both but (and I may be imagining this) the right speaker always seems quieter than the left.
I switched left and right speakers around and they both work ok on the left so it must be something wrong with the amp or the cables (which are also second hand) when it comes to feeding this right channel.
Any ideas what the problem is? (apart from buying from Ebay in the first place )
