Documentation for your setup?
URL
Hi Folks
I have been meaning to document the setup & connections within my AV kit....
I could do with a Visio of it all... but have never seen a template or style sheet type of thing for AV kit.
Anyone got any ideas to make this easier?
I am not artistic, and have limited patience for faffing around, so Visio is really my limit I guess!
I did see a neat diagram in one of th AV comics that showed how to connect things up - that would be a good base for the picture....
There must be something around specifically targeted at this kinda thing - what do the professionals use!??!
DJ
pemberto
DJ,
Have a look at the D:Tools website. http://www.d-tools.com/demos.html D:Toosl is what most of the professional installers use in the US/UK. The web link should take you to the demo page and Sample Drawings & Reports. Take a look at the schematic sample.
You should be able to recreate this in visio with a bit of luck.
Paul
URL
Pemberto!!
Thank you VERY much for that link - it is exaclt what I was looking for!!
You can see why I was reluctant to do it in Visio when there must be something out there that was designed for the job..... either that or my Visio skills are sadly lacking!
Now I guess I need to go see how much of a sore bottom the license fee is....
DJ
pemberto
Sorry mate, forgot to say its not cheap. I ended up using Excel and a very large sheet of paper.
I used excel to build the input/output boxes for each component, printed them out and stuck them on an A0 sheet of paper and then added the connecting lines. As you can see in my sig list I have a few bits of gear so it was a bit of a job.
The other way may be to use visio and have multiple sheets that only show one layer of connection. So one sheet for audio conections and one sheet for video.
Hope that helps.
Paul
URL
I guess layers in Visio will be the way forward...
I just liked that picture I saw in one fo the HC comics... looked nice too!!
I have 11 AV sources... plus 3 audio only sources so its mahem round the back... (so to speak...) Most have multiple paths, ie analogue and PCM audio and some have Composite, component and SVideo connected up too... AGH!!!!
D
pemberto
Hi D,
If only we had those big purpose built av rooms like the US, using those Mid Atlantic racks with all that neat and tidy cabling.
But if we had all that, what would we do.....
Paul
hornydragon
Cedia have a Visio tool set for AV connections (members only) but i think there is an option for custom connections/symbols.
Podcast: New TVs, Samsung Q800T Soundbar review, IFA latest, Movie and AV News, B+W Brad Pitt
