Docking station advice
Rickster32
New to the forum, I currently have a Dell Inspiron 15 5000 15.6" Intel® Core™ i5 laptop, I have had it for about 3 years, it's a non usb-c device. I want to hook it up to at least 2 monitors plus keyboard mouse etc, and know I will need a docking station, I am after some advice as to what to go for, would like to spend no more than £50 ideally, but realise I may have to go above this a bit, and product suggestions world be appreciated, thanks.
EndlessWaves
Which model of laptop is it? The 5000-series has had quite a few models. Is it the 5567?
You don't need a dock to connect more peripherals, the purpose of a dock is to make it easy to frequently connect and disconnect them because there are fewer plugs.
Generally your laptop won't be able to use the video outputs on the majority of docks with a Type C connector, unless they explicitly say that either work with a Type A port or don't require DP Alt Mode support.
Rickster32
I will check the exact model,
Thanks for the reply, the model is 5570, I have been looking at this
Targus Universal Docking Station With Laptop Power, USB-A 3.0, SV 2K, Dual Video 1K Video, Black (DOCK171EUZ)​
https://www.amazon.co.uk/Targus-DOCK171EUZ-Universal-Docking-Station/dp/B07423KK44#
  1. Targus Universal Docking Station With Laptop Power, USB-A 3.0, SV 2K, Dual Video 1K Video, Black (DOCK171EUZ)
EndlessWaves
That should work, provided the monitors you're looking at have those connections and are 1920x1200 or less.
