dobly pro-logic on a lcd/plasma ?
Discussion in 'LCD & LED LCD TVs Forum' started by grizz, May 4, 2004.
Tags:
  1. grizz
    grizz
    Apr 17, 2003
    10
    North West UK
    Hello,
    As this is my first post, i'll only ask one Q for the moment, but I would imagine there will be some more as I get into it.
    At the moment I have a Beko 32" telly with in built Dobly Pro-Logic, due to my good lady wanting to use the space for shelves she asked for a rethink on telly's, we have done some looking and we both like the LCD & Plasmas 37", I'll do some more reading on which type later, but i carnt find any with inbuilt Dolby Pro-Logic.
    Do LCD and/or Plasmas units have this fitted?
    will i have to rethink again?
    My setup at the mo is:-
    Samsung home thearter
    Sony vcr
    Pace analogue satellite receiver ms1000ip (drives my sat system)
    Samsung digital reciver (not sky)
    Nokia ondigi reciver(for freeview)
    All are scarted through a quintrino (something like that)
    Thank you for your time
    Regards
    G
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,688
    Somewhere in South Yorkshire
    +6,255
    "Samsung Home Theatre"
    Is this some type of surround sound amplifier/DVD combo? With 5 speakers etc?
    If yes - then I guess you can use this to give you your surround effects (including Dolby Digital, ProLogic etc) and you don't need it to be fitted in your TV.
    AFAIK, there aren't (yet) any flat panels with DPL or DD onboard. But, as I say, maybe you don't need it anyway.
  3. grizz
    grizz
    Apr 17, 2003
    10
    North West UK
    Thank you for the reply.
    Yes, that's the one.
    Now to re-read the samsung manual again to see how it's done.
    Many thanks again :)
    Regards
    G
  4. LV426
    LV426
    Jul 14, 2000
    13,688
    +6,255
    Seems likely, then, that the Home Theatre thingy will have at least one external stereo input which will be selectable from the remote.
    Depending on whether it has just one, or several, you may need some sort of switching box (is that what you meant by quintrino (something like that)?) so that all the other sources viz:
    Sony vcr
    and, optionally the TV (ie for regular analog TV only) can all be connected to the external stereo input.
    And then, away you go.. I guess.
  5. grizz
    grizz
    Apr 17, 2003
    10
    North West UK
    it's called
    BT945 - "QUINTRO+"
    Home Entertainment Control Centre at
    http://b-tech-int.com/BT945.htm
    Sorry, I should have searched a bit more on what it was called before I posted, :blush:
    regards
    G
  6. LV426
    LV426
    Jul 14, 2000
    13,688
    +6,255
    Yep, that should do it.
    Check your Samsung manual for an external input. Let's assume it has one.
    Connect all your sources to your QUINTRO and then the audio (stereo) output from the QUINTRO into your Samsung, and the video output to the TV. Don't forget to select the external input on the Samsung and the relevant input on the TV at the same time.
  7. grizz
    grizz
    Apr 17, 2003
    10
    North West UK
    Many thanks,
    We now can do a detalied search on type/model.
    Btw the link "Introduction to LCD TVs" on Plasma and LCD displays does not load the pdf file, been to the http://www.whatvideotv.com and the same thing happens there :/ oh well, never mind, i got one of the main Q's sorted.
    Regards
    G
