Do you watch TV on your plasma? If so, how do you connect it yours up?
Discussion in 'Plasma TVs Forum' started by ReimsEvo, Mar 21, 2003.
  1. ReimsEvo
    ReimsEvo
    As the thread title says, if you watch tv on your plasma how do you get your picture......?
    I'm trying to run through an S-VHS vcr to the amp then into the plasma, but the picture is awful !
    Whats your connection flavour ? Most of you use sky boxes I presume? Anyone succesfully using a vcr?
    Cheers. :)
  2. JamesTapp
    JamesTapp
    Oct 2, 2002
    235
    16
    Bedfordshire
    I use NTL cable, from the STB RGB Scart into the famous John Sim RGB -> Component convertor, and then into the plasma.
    If you can get Freeview that would be a much better way of getting a good picture and then go RGB -> VGA or RGB -> Component.
    Take a look at www.rgbtosvideo.com
    James
  3. ReimsEvo
    ReimsEvo
    Doh, sorry I should have mentioned that I cannot get cable or freeview :D :rolleyes:
  4. The Hemulen
    The Hemulen
    Dec 5, 2002
    549
    Cambridge, UK
    +19
    Is Freeview a lot better than Sky on a big screen then? Hope so as I find many of the channels on sky pretty unwatchable quality wise on my plasma. A lot of them content wise too but that's another issue...
  5. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    ReimsEvo ahve you tried any other sources via s-vid to your plasma? Just a thought! You could always try a panny HS2 as it will do component R G B. expensive experiment but might be worth buying from a high street store that will let you take it back no questions. If only argos stocked them!
  6. lab
    lab
    ReimsEvo
    I was using ntl into svhs vcr then svid into plasma and thought pq was okayish then I tried rgb into vga and rgb into component and the improvement was dramatic. Don`t know much about sky but if it has an rgb scart socket I would recommend trying it.
    EDIT sorry ReimsEvo, seem to have misread your post, I thought you had sky already,I don`t envy you if your stuck with the svhs pq, what about something like the pro v maybe someone who uses one can advise.
  7. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  8. Joe Fernand
    Joe Fernand
    Jan 20, 2002
    26,574
    The Borders
    +3,029
    ReimsEvo
    We have used the AverMEDIA TVBox3 (with Teletext) successfully for a coupe of customers in the last few weeks - one customer reckons it outperforms his Nokia Mediamaster FTA box.
    The TVBox3 is around £130 + delivery.
    Best regards
    Joe
  9. ReimsEvo
    ReimsEvo
    Cheers for your replies, I now have a few options atleast :D
    So I presume that an svhs vcr will simply never produce a good signal at all.....
