Do you use Extension tubes ?
Discussion in 'Photography Forums' started by anthony566, Feb 6, 2009.
  1. anthony566
    anthony566
    Nov 20, 2006
    621
    28
    Redcar UK
    +81
    I would like to here if and what you use these for and the results you get from them ?
    Thanks in advance :thumbsup:
  2. T0MAT01
    T0MAT01
    Dec 25, 2004
    2,383
    113
    Devon, Sussex or somewhere inbetween.
    +552
    An extension tube will reduce the minimum focus distance of a lens which can be handy for macro work.
    I use them, and while they're obviously not as good as having a macro lens, they are a fairly handy alternative although the image quality is reduced from what the lens would produce without it.
    I find that Live View is a god send when using them as it really helps to get the focus spot on.
    A few shots I've taken with mine here.
    HTH.
  3. anthony566
    anthony566
    Nov 20, 2006
    621
    28
    Redcar UK
    +81
    :thumbsup:Thanks TOMATO1 Im really interested in whay people use them and a look at some of the results... the images you sent look great thanks.
  4. Mike.P®
    Mike.P®
    Feb 26, 2008
    2,705
    +527
    I have a set I bought purely because they were a bargain and I couldn't refuse them. (on Ebay with a 50mm AF f1.7 lens for £25 .. the tubes themselves are worth double that). Anyway, apart from one shot I havent played with them much because I use my Macro lens but here is the picture.
    The interesting thing is it was taken using the tubes and a 300mm f4.5 prime lens.
    Quite pleased with it actually.
    [​IMG]
  5. anthony566
    anthony566
    Nov 20, 2006
    621
    28
    Redcar UK
    +81
    I like the image.. interesting you used it with a 300mm:thumbsup: Thanks.
  6. D-an-W
    D-an-W
    Sep 23, 2006
    1,795
    +184
  7. Holowlegs
    Holowlegs
    Oct 18, 2005
    4,278
    Ruislip, London
    +1,017
    Hello there
    I have been reading a bird photography book, and they suggest sometimes to use extension tubes on long primes, 400mm, 500mm, 600mm.
    Never tried it myself.
    Cheers Holo:smashin::smashin:
