Do you need to have the hard driver recorder on to watch TV?
Discussion in 'LCD & LED LCD TVs Forum' started by playthefilm, Nov 26, 2010.
Tags:
  1. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    Quick question, which I'm sure someone will have a quick answer too.
    Recently helped a family member set up a Panasonic TV with Panasonic HDD/DVD recorder.
    Arial cable goes to HDD/DVD recorder.
    RF out (ie arial cable) goes from HDD/DVD recorder to TV.
    SCART cable goes from HDD/DVD recorder to TV.
    HDMI cable goes from HDD/DVD recorder to TV.
    However, the only way to watch freeview (DVB) is to have the HDD/DVD recorder turned on.
    Surely you must be able to watch TV without needing that on (or am I mistaken?).
    Any help would be greatly appreciated, thanks.
  2. Kalos Geros
    Kalos Geros
    Sep 4, 2005
    2,101
    Croatia
    +136
    If the TV has a DVB-T tuner bulit-in then you don't need the DVDR to be turned on...otherwise you DO! Which Panasonic TV model is it exactly?
  3. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    thanks Kalos,
    its the TX-L37G20B
  4. JayCee
    JayCee
    Jan 20, 2004
    23,761
    Lanarkshire
    +2,570
    More to the point which model of DVDR is it as some models have a "green" power saving mode which turns of Rf passthrough when it's activated..meaning no aerial signal to the Tv...if it isn't this you simply need to press the button marked TV on the Tv remote.
  5. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    it's the DMR-EX773EB, thanks Jaycee
  6. JayCee
    JayCee
    Jan 20, 2004
    23,761
    Lanarkshire
    +2,570
    Before we go any further by "turned on" do you mean switched on by the power/standby button or "turned on" at the mains plug?
  7. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    turned on at the standby/power on button.
  8. playthefilm
    playthefilm
    Jul 2, 2004
    1,183
    48
    +59
    sorted - it worked removing the scart cable!
    thanks all :thumbsup:
  9. JayCee
    JayCee
    Jan 20, 2004
    23,761
    Lanarkshire
    +2,570
    Just re-read your 1st post and hadn't noticed you had it connected by scart and HDMI...no need for both it's one or the other, anyway as you've just posted removing the scart lead allows you to watch the Freeview via the TVs tuner I again just realised all you had to do in that case was press the TV button on the TV remote as the scart connected DVDR auto-switches the Tv to the DVDR.
  10. shanks197
    shanks197
    If the hard drive recorder is freeview box then yes
  11. JayCee
    JayCee
    Jan 20, 2004
    23,761
    Lanarkshire
    +2,570
