Do you need an upscaler DVD player with Panasonic 42PV500
Discussion in 'Panasonic TVs Forum' started by TastyMango, Aug 30, 2005.
  1. TastyMango
    TastyMango
    Just bought a Panasonic 42PV500 plasma.
    I now want to get a dvd player and am a little confused.
    I have heard about dvd players which upscale the picture so that you get the best out of the display. Two models which I am looking at are the Samsung DVDHD850 and NeuNeo HVD2085.
    But I am confused because I now hear that the Panasonic plasma upscales the image anyway.
    Do I need a DVD which upscales the image or will any dvd player with component output be ok?
  2. ukdan
    ukdan
    Feb 16, 2005
    1,135
    swindon
    +85
    Any dvd player will do, the panel will upscale to its own resolution. Just get a good component output and enjoy.
  3. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    The PV500 doesn't appear to have any form of film detection on board. I would recommend looking at a DVD player that has 2:2 and 2:3 detection and can output 480p/576p. This could be by component or HDMI. Either should offer an obvious improvement in image quality of a standard interlaced feed to this display
    Gordon
  4. guli
    guli
    Sep 3, 2004
    412
    16
    gordon,
    is it true for all panasonic boards or just the pv500?
    what about pwd6? Does it have 2:2 and 2:3 detection?
    Alex
  5. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
  6. TastyMango
    TastyMango
    So are you saying that an upscaling dvd player like the Samsung DVDHD850 or NeuNeo HVD2085 isn't required for the PV500?
    What exactly is all this 2:2 & 2:3 detection all about?
  7. theo cupier
    theo cupier
    Sep 18, 2004
    1,660
    63
    Amersham, Bucks
    +113
    Sorry, I'd just got the hang of HDCP, HDMI, native resolution (I think) and 50Hz v 60Hz nd now we get 2:2 and 2:3 detection.
    Can someone explain the issue (generally & simply) before my brain melts in this heat. [​IMG]
  8. yellowpostit
    yellowpostit
    Jun 27, 2005
    177
    19
    Nottingham
    I'd just started trying to understand this as soon as I read Gordon's post. It sounds like an NTSC issue, but my brain is fried too. I did a search on here and found nothing obviously helpful. help!
  9. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
  10. mohit_ranjan
    mohit_ranjan
    Sep 18, 2006
    11
    Tastymango and others with the Panasonic TH 42pv500, did you buy an upscaling DVD player? I have the same issue and am not sure what to do.
    Cheers!
