Do you know why my sky picture break-ups ever for minutes?
Discussion in 'Sky Digital TV Forum' started by stokelake, Dec 31, 2006.
  1. stokelake
    stokelake
    Dec 26, 2004
    28
    My sky picture breaks up for a split second every few minutes, especially on UKTV channels, but on some other channels sometimes too.
    Not all the picture breaks up just part of it, which is accompanied with a high pitched sound.
    What could be causing this? I have called Sky twice and they have taken me through a few "basic proceedures" by the problem still occurs.
    You help would be appreciated.
    J.
  2. dan54
    dan54
    Mar 27, 2006
    1,261
    63
    +107
    Im getting this on UKTV channels too but I read somewhere on here that its down to them-been going on for a few weeks now.
  3. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    Most probably a faulty LNB or slightly misaligned dish or the tuner failing within the STB. Other factors although rarer can be the cable and digital portable phones placed near to the STB.
    Cheers, Franc
  4. stokelake
    stokelake
    Dec 26, 2004
    28
    Hi Franc,
    thanks for the reply but what does LNB and STB mean?
    If they are the problem what can i do to fix them?
    thanks,
    j.
  5. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
  6. cerebros
    cerebros
    Dec 27, 2002
    1,364
    48
    Leicester
    +42
    Have the break-ups coincided with poor weather in your locality? Supposedly only extreme conditions should cause break-up, but reading around here in relation to problems I'm having, it would seem that bad weather, sub-optimal installation and/or faulty LNB or box could be behind the symptoms you're seeing
  7. stokelake
    stokelake
    Dec 26, 2004
    28
    No it doesn't seems to be the weather, it happens when its sunny or raining.
  8. colger
    colger
    I have the same problem on UKTV channels only. I have also noticed that when the 'breakup' occurs, the sound can loose sync with the vision.
  9. FRANTIC FRANC
    FRANTIC FRANC
    Aug 7, 2006
    1,375
    63
    +86
    LNB is the low noise block (the bit at the end of your dish arm). STB is the set top box (AKA the Sky digibox).
    The first thing to try is a force update. If this doesn't work then buy a new LNB and replace with the old one. Or better still try someone else's STB on your dish and see if the same fault occurs to know for sure or take your STB to another dish and try.
    Cheers, Franc
