do u think its a good spec
Discussion in 'Projectors, Screens & Video Processors' started by shawn, Sep 6, 2004.
  1. shawn
    shawn
    Aug 29, 2004
    500
    birmingham
    +7
    thinking about buying this sony projector,
    heres the specs, do u think its a good spec model?
    Brightness (Lumens) : 3500 ANSI
    Contrast: ANSI: **
    Full On/Off: 700:1
    Weight: 16.5 lbs.
    Size (inches) (HxWxD) : 4.6 x 16.6 x 12.5
    Throw Dist (feet) : 6.2 - 38.0
    Image Size (inches) : 40.0 - 300.0
    Lens: Focus:
    Manual
    Zoom: Manual, 1.25:1
    Optional Lenses: Yes
    Digital Zoom: Yes
    Keystone Correction: Digital
    Lens Shift: **
    Compatibility: HDTV:
    1080i, 720p
    EDTV/480p: Yes
    SDTV/480i: Yes
    Component Video: Yes
    Video: Yes
    Digital Input: DVI-D
    Personal Computers: Yes
    Networking: Wired:
    Yes
    Wireless: No
    Warranty: 2 Years
    Lamp: Type:
    265W UHP
    Life: **
    Quantity: 1
    Display: Type:
    1.0" PolySi LCD (3)
    Native: 1024x768 Pixels
    Maximum: 1600x1200 Pixels
    Aspect Ratio: 4:3 (XGA)
    Performance:
    H-Sync Range: 19.0 - 92.0kHz
    V-Sync Range: 48 - 92Hz
    Pixel Clock: **
    Speakers: 2.0W+ 2.0W
    Max Power: 365W
    Voltage: 100V - 240V
    FCC Class: A
    Audible Noise: **
    Special: **
    Status: Shipping
    First Ship: Nov 2002
    will be useing it on a 102" screen, my room length is 16 foot
    will be used for tv and dvd viewing.
    or should i go for somethink like this dell projector?
    http://www.projectorcentral.com/Dell-2200MP.htm
  2. Crustyloafer
    Crustyloafer
    Sep 12, 2003
    9,566
    Edinburgh
    +1,266
    That looks like a data projector to me. Far too bright for home cinema use and very poor contrast ratio. You should be looking for somehting with dedicated widescreen DLP chip like the Matterhorn @ 1024x576 resolution or the Mustang HD2 and HD2+ which are even better. Brightness should really be less than 1000 ANSI lumens and a contrast ration near 2000:1 or higher is what you want. The Dell machine looks like a better bet for movies b ut I wouold also consider the Themescene H30 and the Screenplay 4805 which come in near that price point.
