Do u have 2 use Media box on Hit 42PD3000 if you've got Sky+?
Discussion in 'Plasma TVs Forum' started by Cag, Jan 10, 2004.
  1. Cag
    Cag
    Nov 16, 2003
    235
    Newcastle
    +9
    Can u just use the Sky+ box as your tuner?
  2. Elvis
    Elvis
  3. JAMBO
    JAMBO
    All connections for scarts etc are on media box, which then has 1 connection to screen. However, sensor for remote is on screen...not on media box, so it can be hidden away, if required.
    Media box is actually quite useful for teletext. I find the Skytext inferior to analogue BBC Ceefax and ITV Teletext.
  4. MAW
    MAW
    Jan 24, 2002
    14,103
    Nr Dorking
    +411
    Don't forget if you want to do this Hitachi make a screen just for you, the PMA400/500. Easy and cheap to connect with RGB and sync. cable, results are often very good. The down side is that you can't buy it from JL with a reassuring 5 yr warranty.
  5. Cag
    Cag
    Nov 16, 2003
    235
    Newcastle
    +9
    So can the media box be hidden out of sight & still have full control over all things (incl. the Teletext??)
  6. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Yes, you'll not lose any control over the media box if it is hidden as the remote sensor is on the screen itself.
    John
