Do trees affect freeview?
Discussion in 'Freeview & YouView' started by azz, May 13, 2005.
  1. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    I had a good arial put up on the side of my house last year and had no problems. Then i put a sky dish under it 2-3 feet and i had a very occational problem with channel five. Now the tree that the areial was pointing at has grown leaves and is quite thick. I have lost channel5 qvc and others.
    Is it the trees, or has the tramitter for nottingham been damged etc. I have a spare Thomson freeview box and the same problesm as the sagem.
    Looking at the technical data the channel signal quality is poor
    Please advise-the arial is on the side of the chiminey stack i guess the next thing to do is buy a pole but the areial cables are a little short
    azz :lease:
  2. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,440
    Somewhere in South Yorkshire
    +5,851
    The short answer to your question is "yes" - trees can reduce signal strength, which, in turn, increases the likelihood of corruption. Ideally, you need to get as near to line-of-sight with the transmitter, as you can. A higher gain aerial, and/or differently positioned seems to be needed.
  3. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Thanks nigel but the BBC and ITV123 are all fine weard?
    The tree is huge
    I will let u know after the WEnd
    Azz
  4. azz
    azz
    Feb 22, 2003
    644
    28
    Nottingham
    +22
    Also the arial is a high gain arial for very week signals already!
    Azz
  5. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Digital signals are like that - things either work, or they don't. If you were "borderline" for signals before the leaves appeared, the leaves probably pushed the signal below the level needed to lock.
