Do superbit discs play in any player?
Discussion in 'Movie Forum' started by ajf, Sep 20, 2004.
  1. ajf
    ajf
    Sep 20, 2004
    96
    Header says it all!
    Andrew
  2. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Yes they do. It's just a bare bones movie with a DD and DTS soundtrack.
  3. krusty
    krusty
    although i think superbits look better through projectors
  4. Rob20
    Rob20
    Jul 3, 2004
    3,107
    +665
    Having a couple of superbit dvd's, i.e. Gladiator and leon, I can't see all that much of an imrpvement over standard dvds, (brother has standard Gladiator). Waste of time unless the differences are more noticeable on a large screeen, 42"+ perhaps. Not that noticeable on a 26" lcd. Though maybe you need a high end dvd? only have Pan dvd rec dmr85.
  5. ajf
    ajf
    Sep 20, 2004
    96
    Thanks for the replies.
    Just curious really as there were acouple titles on eBay that are superbit and they were cheaper than the normal release.
    Andrew
  6. ns1col
    ns1col
    Feb 22, 2004
    202
    Aberdeen, Scotland
    Play are doing superbit versions for £9.99 if that helps.
  7. Smurfin
    Smurfin
    Aug 13, 2002
    21,427
    +4,370
    Depends on the disc, on my old 7.5' screen, I couldn't see a difference on all the ones I tested. A couple of people have commented that they CAN see improvements, but are running video setups which would probably be a mortgage to many people :)
  8. Smurfin
    Smurfin
    Aug 13, 2002
    21,427
    +4,370
  9. Marv
    Marv
    Jun 7, 2002
    2,772
    Kekistan
    +1,021
    Desperado now theres superbit which is worth the ££££(£10) IMO. Bad Boys Superbit on the other hand......
