do r2 discs work on lg 3350e hack on r1 setting?
Discussion in 'Blu-ray & DVD Player Multiregion Hacks' started by DPS, May 17, 2001.
  1. DPS
    DPS
    Read in a mag today that the lg hack on the 3350e, when set on region 1 will play region 2 discs with out setting it back to region 2 is this true.I tried the hack months ago but without a region 1 disc to see if it works, i was reduced to putting the code to region 1 and seeing if the player would reject the region 2 disc.The disc played so i just thought the hack didnt work on my 3350e due to it being an early model or something but if the above is true then the hack probly worked originally. Can some one please clear this matter up for me as i am desperate to start collecting region 1 discs.
  2. Fartpants
    Fartpants
    Why don't you buy or borrow a region 1 disc to find out?
