Do PC DVD Re-Writers accept VR mode?
Discussion in 'Blu-ray & DVD Players & Recorders' started by witters, Nov 10, 2004.
  1. witters
    witters
    Jul 13, 2000
    12,658
    Yorkshire
    +293
    As header.
    Can you play a VR mode disc in a PC burner please?
  2. TBH1
    TBH1
    Sep 1, 2004
    25
    Birmingham
    witters - I am probably newer at this than you but got my first DVD writer yesterday and still 'messing' with it. I recorded something last night in VR mode - and PC would not recognise it. I did not finalise this, not sure right now if you do finalise VR mode DVD's. Will record something tonight in video mode and see if PC recognises that, with and without finalisation.
    probably no help what-so-ever - - - -I'll get me coat !!
  3. witters
    witters
    Jul 13, 2000
    12,658
    Yorkshire
    +293
    Thanks :smashin:
  4. Kevo
    Kevo
    Aug 23, 2001
    5,408
    Manchester
    +151
    Yes, well my LG does.
    Also depends on the software you use.
    TMPG DVD Author certainly supports it
  5. witters
    witters
    Jul 13, 2000
    12,658
    Yorkshire
    +293
    Thanks for that.
  6. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Deepest Hertfordshire
    VR mode DVDs are not finalised. Finalising is only for Video mode.
  7. witters
    witters
    Jul 13, 2000
    12,658
    Yorkshire
    +293
    Are you sure that's correct? I have seen finalised VR mode discs.
  8. PhilipL
    PhilipL
    Jan 18, 2002
    3,843
    103
    +444
    VR Mode discs should work fine in all DVD readers provided it reads DVD-RW discs. VR mode discs do not require finalising.
    However Windows does not have file system drivers for reading the UDF version 2 file format used (Longhorn will), so you may get an "Invalid Function" message if trying to view the disc contents.
    All DVD Player software and most authoring packages like ULead MovieFactory 3 contain their own UDF file system drivers and will play or import from the disc, even though Windows refuses to acknowledge it.
    If you want to see the disc contents in Windows explorer you can download InCD4 (the InCD reader is free http://www.nero.com/en/26230.html).
    Regards
    Philip
  9. OARDVD
    OARDVD
    Jul 6, 2003
    241
    16
    Well ok, VR mode -RW discs can optionally be “finalised” (fixed) but it's not the same as making them DVD compatible (ie Video mode) which is generally what is meant by finalising.
