Do Panasonic players take caddied DVD-Ram?
Discussion in 'Blu-ray & DVD Players & Recorders' started by jem, Nov 20, 2003.
  1. jem
    jem
    Sep 24, 2002
    527
    +7
    Can the Panasonic S75 player take caddied DVD-Ram or is it only the recorders?
    If not can any of the DVD-Ram discs that come in caddies be easily taken out of the caddy to play in the S75?
  2. CARLOS
    CARLOS
    Feb 11, 2001
    6,456
    WEST MIDLANDS
    +1,412
    No you have to remove the disc from the caddy to play it in one of the players.
    They can be removed very easily, Just break out the little yellow lug then push the catch at the edge of the disc with your nail and it comes open.
  3. jem
    jem
    Sep 24, 2002
    527
    +7
    Is that with any particular make or are they all the same?
  4. jem
    jem
    Sep 24, 2002
    527
    +7
    I found instructions for the DVD-Ram that I had just purchased. They were marked on the web site and also ( if I'd looked! ) in the box that the pack of 5 came in.
    Seems easy enough now that I've had a go.
