Do lamps deteriorate when they're not being used?
Discussion in 'Projectors, Screens & Video Processors' started by dancingmatt, May 17, 2005.
  1. dancingmatt
    dancingmatt
    Apr 26, 2005
    433
    +13
    Hi all
    I've seen one or two deals where you get an extra lamp thrown (not literally!) in free with a projector. I'm wondering if the quality of a lamp could expire before it is used?
    I mean for the expense of buying a projector I know I'm going to use it more than I expect to ;) but if I get a full life out of the lamp then it's going to last me 3 or 4 years. So would a free bulb be as good in 3 or 4 years time as it is now?
    Could it deteriorate with age even though it's not been used?
    What do you think? Thanks
    DM
  2. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    Lamps will probably keep indefinitely if not used.
    The inert gases used in lamps will actually preserve the internal structure for a very long time.
    Jeff
  3. PJTX100
    PJTX100
    Dec 21, 2004
    8,132
    +563
    If something expensive crops up when just out of warranty, having shelled out for an extra bulb may either prove to be wasted money or cramp your options...PJ :)
    Edit... didn't read the freebie bit... and delete doesn't seem to work. :)
