Hi there
I have a Sony DVP-NS30 DVD player and one of the settings in the audio options is MPEG. You can put it on PCM or MPEG, was not sure which one to put it on. The amp is a TEAC AG-10D and the Sony manual says if the amp has a MPEG decoder select the MPEG option. But I dont know if it has, does anyone know if it has and if this is the setting I should put it on? Does most surround sound amps have MPEG decoders?
Thanks for any help
Thanks for any help
