Do I really need my "midwoofer"?
Discussion in 'Subwoofers' started by Brian Kendig, Dec 2, 2004.
  1. Brian Kendig
    Brian Kendig
    Jul 13, 2001
    25
    A few years ago I purchased a set of five small Cambridge Soundworks speakers. They came with a small subwoofer which the instructions told me to wire together with the front right/left speakers to provide a little extra bass.
    Later I purchased a subwoofer, which has its own connection to the receiver. So now I'm wondering... is that small woofer, wired in with the right/left speakers, really necessary? I'm guessing it still is, that it captures midrange sounds too high for the sub but too low for the small speakers, but I wanted to get some opinions from people who are familiar with this sort of thing.
  2. Grif
    Grif
    Jul 28, 2004
    261
    +4
    Personally I'd keep it, but wire it into the centre.... if its mainly for movies.
  3. Reiner
    Reiner
    Jul 16, 2000
    3,315
    61
    Germany
    +13
    You could remove the old subwoofer and set all your speakers to SMALL, thus sending the low(er) frequencies to the subwoofer that is directly connected to the Av amp/receiver.
    Or just leave your "midrange" woofer where it is, depending on your preference.
